msgdma descriptor fifo depth
Hi Matt1,
the DMA is not used to hold all the data that you want to transfer at once. A DMA transfers data chunk wise. Therefore, you have to split your source data (1GB) into chunks of data that fit into your DMA data fifo and then you push the DMA transaction into the descriptor fifo.
As an example, if you configure the MSGDMA with a Maximum Transfer Length of 4KB and a Descriptor FIFO Depth of 256 then you can instruct the MSGDMA to transfer data chunks of maximum 4KB at a time. While the first 4KB are initiated and are tranferred you can already push the next 4KB into the MSGDMA but since the DMA is busy they will be pushed into the descriptor fifo. As configured you can push 256 data chunks into the descriptor fifo. Whenever a transaction is done and there is another transaction queued in the descriptor fifo the next data chunk will be transferred until the descriptor fifo is empty.
Back to your 1GB task. If you want to transfer the data in 20Byte chunks, you need a pseudo code like the following
start_addr = where your data is size = 1024 * 1024 * 1024 // 1GB chunk_size = 20 end_addr = start_addr + size chunk_start_addr = start_addr do { wait until descriptor buffer is not full push descriptor with start addr of "chunk_start_addr" and "chunk_size" bytes to transfer chunk_start_addr += chunk_size } while(chunk_start_addr < end_addr) push descriptor with the remaining bytes wait until transfer is done
Although transmitting chunks of 20 bytes will work, I recommend you to transfer as many bytes as you configure in the MSGDMA component via "Maximum Transfer Length"
I hope this helps.
- Matt15 years ago
Hello TKruse,
thank you for your detailed reply.
