12 years agoMPEG Transport stream over IP?
hi i search a IP Core that can convert the MPEG transportstream (ASI (e.g with the ASI-Megafunction) or SPI) to ethernet. i find only the "10G RTP Video over IP" from Macnica. This is only...
9 years agoThe link corrected.
For VLC or even TV play, jitter is not a problem. It could be a disaster if you want to broadcast it using DVB modulators. So forget about jitter in your project. The 188-byte TS becomes the RTP payload, but there are other fields that should be inserted, like Time Stamp, Sequence Number, etc. Study the SMPTE-2022-2 standard for more detail.
