12 years agoMPEG Transport stream over IP?
hi i search a IP Core that can convert the MPEG transportstream (ASI (e.g with the ASI-Megafunction) or SPI) to ethernet. i find only the "10G RTP Video over IP" from Macnica. This is only...
9 years agoThanks guys for your replies.
@msj the second link does not work. The idea is: take some TS directly from a front-end and wrap intoa UDP stream, then watch using VLC on my pc or using raspberry pi connected to the TV thru HDMI Maybe it's a silly question: does the 188-byte packet of TS became the RTP payload? Is there any low cost board with an altera fpga and ethernet adapter? I have already bought a Terasic De0 Nano (cyclone IV) but it has not theethernet adapter. Could you advice anything?
