12 years agoMPEG Transport stream over IP?
hi i search a IP Core that can convert the MPEG transportstream (ASI (e.g with the ASI-Megafunction) or SPI) to ethernet. i find only the "10G RTP Video over IP" from Macnica. This is only...
9 years agoHi Socrates,
I'm very interested in trasmission of a TS over IP network, but I'm starting now thinking about the problem. Could you explain better your solution and share any code? Are you encapsulate the 188-bytes of each TS directly into an UDP (example multicast???) and are you able to receive on a laptop connected to the network using for example VLC? It's also very interesting the possibility to add LwIP and Nios could you provide more details? Thanks in advance
