13 years agoModular SGDMA - Doubt on Target Address
I am using the "ALT_PCIE_QSYS_SIMPLE" sample application. The code is executed successfully. It had leaded me to the following doubts: --------- Doubt 1 --------- By default, the targe...
13 years agoThank you for your reply. I still have the following doubt.
- Where is the master settings? - Do you mean putting a loop over the ReadDMA function? - How about the target address doubt? I need to specify 0x07000000, if other target address, PC will hang?
