AFahr2's avatar
AFahr2
6 years ago
Modelsim error on alt_dual_boot and altera_onchip_flash_block - Error: (vsim-3033): Instantiation of 'altera_onchip_flash_block' failed. The design unit was not found.
Hello all,
I'm trying to simulate a simple SPI - Flash interface using:
  • Spi_Slave
  • Avalon bytes to packets and Packets to bytes
  • Packets to master
  • Onchip Flash
  • Dual Boot
  • Clk
I'm using the Lite edition of Quartus 18.1, Platform Designer 18.1 and ModelSim - INTEL FPGA STARTER EDITION 10.5b.
I can generate the code with platform designer and compile it with Quartus. I have a testbench file to simulate the SPI interface. I have followed the instructions on "Simulating in ModelSim-Altera Edition usingNativeLink" (https://www.intel.com/content/dam/altera-www/global/en_US/kdb/rd10312011_847/nativelink_simulation.pdf) and that all has worked out well. I can start the simulation using "Tools -> Run Simulation Tool -> RTL Simulation".
When the simulation starts, I get following errors on the ModelSim output:
** Error: (vsim-3033) d:/projects/vhdl/spi_flash/db/ip/rsu_test/submodules/altera_onchip_flash.v(309): Instantiation of 'altera_onchip_flash_block' failed. The design unit was not found.
# Time: 0 ps Iteration: 0 Instance: /spi_flash_tb/DUT/u0/onchip_flash_0 File: d:/projects/vhdl/spi_flash/db/ip/rsu_test/submodules/altera_onchip_flash.v
Error: (vsim-3033) d:/projects/vhdl/spi_flash/db/ip/rsu_test/submodules/altera_dual_boot.v(41): Instantiation of 'alt_dual_boot_avmm' failed. The design unit was not found.
# Time: 0 ps Iteration: 0 Instance: /spi_flash_tb/DUT/u0/dual_boot_0 File: d:/projects/vhdl/spi_flash/db/ip/rsu_test/submodules/altera_dual_boot.v
What I've tried so far:
  • Removing the Onchip Flash and Dual Boot IPs from Qsys: Everything works well, but without the flash and dual boot functionality.
  • Adding alt_dual_boot_avmm.v and altera_onchip_flash_block: These files are within the folders as encrypted files, I could not find a way to link them into Modelsim by changing my simulation.do file in the modelsim folder.
At this point, any help would be greatly appreciated, or workaround as well.
Albert F.
  • KennyT_altera's avatar
    KennyT_altera
    Can you used:
    do <design_name>_run_msim_rtl_vhdl.do
    Look into the .do files what simulation model is needed.
    Kenny
  • AFahr2's avatar
    AFahr2
    Hi Kenny, thanks for your reply.
    I actually do use "do spi_flash_run_msim_rtl_vhdl.do", which is generated by Quartus I believe.
    That's when I get the error message. The file "do spi_flash_run_msim_rtl_vhdl.do" looks like this (sorry if this is a bit long):
    transcript on
    if {[file exists rtl_work]} {
    vdel -lib rtl_work -all
    vlib rtl_work
    vmap work rtl_work
    vlib rsu_test
    vmap rsu_test rsu_test
    vlog -vlog01compat -work rsu_test +incdir+d:/projects/vhdl/spi_flash/db/ip/rsu_test/submodules {d:/projects/vhdl/spi_flash/db/ip/rsu_test/submodules/altera_avalon_packets_to_master.v}
    vlog -vlog01compat -work rsu_test +incdir+d:/projects/vhdl/spi_flash/db/ip/rsu_test/submodules {d:/projects/vhdl/spi_flash/db/ip/rsu_test/submodules/altera_avalon_st_bytes_to_packets.v}
    vlog -vlog01compat -work rsu_test +incdir+d:/projects/vhdl/spi_flash/db/ip/rsu_test/submodules {d:/projects/vhdl/spi_flash/db/ip/rsu_test/submodules/altera_avalon_st_packets_to_bytes.v}
    vlog -vlog01compat -work rsu_test +incdir+d:/projects/vhdl/spi_flash/db/ip/rsu_test/submodules {d:/projects/vhdl/spi_flash/db/ip/rsu_test/submodules/altera_dual_boot.v}
    vlog -vlog01compat -work rsu_test +incdir+d:/projects/vhdl/spi_flash/db/ip/rsu_test/submodules {d:/projects/vhdl/spi_flash/db/ip/rsu_test/submodules/altera_onchip_flash.v}
    vlog -vlog01compat -work rsu_test +incdir+d:/projects/vhdl/spi_flash/db/ip/rsu_test/submodules {d:/projects/vhdl/spi_flash/db/ip/rsu_test/submodules/altera_onchip_flash_avmm_csr_controller.v}
    vlog -vlog01compat -work rsu_test +incdir+d:/projects/vhdl/spi_flash/db/ip/rsu_test/submodules {d:/projects/vhdl/spi_flash/db/ip/rsu_test/submodules/altera_onchip_flash_avmm_data_controller.v}
    vlog -vlog01compat -work rsu_test +incdir+d:/projects/vhdl/spi_flash/db/ip/rsu_test/submodules {d:/projects/vhdl/spi_flash/db/ip/rsu_test/submodules/altera_onchip_flash_util.v}
    vlog -vlog01compat -work rsu_test +incdir+d:/projects/vhdl/spi_flash/db/ip/rsu_test/submodules {d:/projects/vhdl/spi_flash/db/ip/rsu_test/submodules/altera_reset_controller.v}
    vlog -vlog01compat -work rsu_test +incdir+d:/projects/vhdl/spi_flash/db/ip/rsu_test/submodules {d:/projects/vhdl/spi_flash/db/ip/rsu_test/submodules/altera_reset_synchronizer.v}
    vlog -vlog01compat -work rsu_test +incdir+d:/projects/vhdl/spi_flash/db/ip/rsu_test/submodules {d:/projects/vhdl/spi_flash/db/ip/rsu_test/submodules/rsu_test_avalon_st_adapter.v}
    vlog -vlog01compat -work rsu_test +incdir+d:/projects/vhdl/spi_flash/db/ip/rsu_test/submodules {d:/projects/vhdl/spi_flash/db/ip/rsu_test/submodules/rsu_test_avalon_st_adapter_001.v}
    vlog -vlog01compat -work rsu_test +incdir+d:/projects/vhdl/spi_flash/db/ip/rsu_test/submodules {d:/projects/vhdl/spi_flash/db/ip/rsu_test/submodules/rsu_test_mm_interconnect_0.v}
    vlog -vlog01compat -work rsu_test +incdir+d:/projects/vhdl/spi_flash/db/ip/rsu_test/submodules {d:/projects/vhdl/spi_flash/db/ip/rsu_test/submodules/rsu_test_mm_interconnect_0_avalon_st_adapter.v}
    vlog -vlog01compat -work rsu_test +incdir+d:/projects/vhdl/spi_flash/db/ip/rsu_test/submodules {d:/projects/vhdl/spi_flash/db/ip/rsu_test/submodules/spiphyslave.v}
    vlog -vlog01compat -work rsu_test +incdir+d:/projects/vhdl/spi_flash/db/ip/rsu_test/submodules {d:/projects/vhdl/spi_flash/db/ip/rsu_test/submodules/altera_avalon_sc_fifo.v}
    vlog -sv -work rsu_test +incdir+d:/projects/vhdl/spi_flash/db/ip/rsu_test/submodules {d:/projects/vhdl/spi_flash/db/ip/rsu_test/submodules/altera_merlin_arbitrator.sv}
    vlog -sv -work rsu_test +incdir+d:/projects/vhdl/spi_flash/db/ip/rsu_test/submodules {d:/projects/vhdl/spi_flash/db/ip/rsu_test/submodules/altera_merlin_burst_uncompressor.sv}
    vlog -sv -work rsu_test +incdir+d:/projects/vhdl/spi_flash/db/ip/rsu_test/submodules {d:/projects/vhdl/spi_flash/db/ip/rsu_test/submodules/altera_merlin_master_agent.sv}
    vlog -sv -work rsu_test +incdir+d:/projects/vhdl/spi_flash/db/ip/rsu_test/submodules {d:/projects/vhdl/spi_flash/db/ip/rsu_test/submodules/altera_merlin_master_translator.sv}
    vlog -sv -work rsu_test +incdir+d:/projects/vhdl/spi_flash/db/ip/rsu_test/submodules {d:/projects/vhdl/spi_flash/db/ip/rsu_test/submodules/altera_merlin_slave_agent.sv}
    vlog -sv -work rsu_test +incdir+d:/projects/vhdl/spi_flash/db/ip/rsu_test/submodules {d:/projects/vhdl/spi_flash/db/ip/rsu_test/submodules/altera_merlin_slave_translator.sv}
    vlog -sv -work rsu_test +incdir+d:/projects/vhdl/spi_flash/db/ip/rsu_test/submodules {d:/projects/vhdl/spi_flash/db/ip/rsu_test/submodules/altera_merlin_traffic_limiter.sv}
    vlog -sv -work rsu_test +incdir+d:/projects/vhdl/spi_flash/db/ip/rsu_test/submodules {d:/projects/vhdl/spi_flash/db/ip/rsu_test/submodules/rsu_test_avalon_st_adapter_001_channel_adapter_0.sv}
    vlog -sv -work rsu_test +incdir+d:/projects/vhdl/spi_flash/db/ip/rsu_test/submodules {d:/projects/vhdl/spi_flash/db/ip/rsu_test/submodules/rsu_test_avalon_st_adapter_channel_adapter_0.sv}
    vlog -sv -work rsu_test +incdir+d:/projects/vhdl/spi_flash/db/ip/rsu_test/submodules {d:/projects/vhdl/spi_flash/db/ip/rsu_test/submodules/rsu_test_mm_interconnect_0_avalon_st_adapter_error_adapter_0.sv}
    vlog -sv -work rsu_test +incdir+d:/projects/vhdl/spi_flash/db/ip/rsu_test/submodules {d:/projects/vhdl/spi_flash/db/ip/rsu_test/submodules/rsu_test_mm_interconnect_0_cmd_demux.sv}
    vlog -sv -work rsu_test +incdir+d:/projects/vhdl/spi_flash/db/ip/rsu_test/submodules {d:/projects/vhdl/spi_flash/db/ip/rsu_test/submodules/rsu_test_mm_interconnect_0_cmd_mux.sv}
    vlog -sv -work rsu_test +incdir+d:/projects/vhdl/spi_flash/db/ip/rsu_test/submodules {d:/projects/vhdl/spi_flash/db/ip/rsu_test/submodules/rsu_test_mm_interconnect_0_router.sv}
    vlog -sv -work rsu_test +incdir+d:/projects/vhdl/spi_flash/db/ip/rsu_test/submodules {d:/projects/vhdl/spi_flash/db/ip/rsu_test/submodules/rsu_test_mm_interconnect_0_router_001.sv}
    vlog -sv -work rsu_test +incdir+d:/projects/vhdl/spi_flash/db/ip/rsu_test/submodules {d:/projects/vhdl/spi_flash/db/ip/rsu_test/submodules/rsu_test_mm_interconnect_0_rsp_demux.sv}
    vlog -sv -work rsu_test +incdir+d:/projects/vhdl/spi_flash/db/ip/rsu_test/submodules {d:/projects/vhdl/spi_flash/db/ip/rsu_test/submodules/rsu_test_mm_interconnect_0_rsp_mux.sv}
    vcom -93 -work work {D:/Projects/VHDL/spi_flash/spi_flash.vhd}
    vcom -93 -work rsu_test {d:/projects/vhdl/spi_flash/db/ip/rsu_test/rsu_test.vhd}
    vcom -93 -work work {D:/Projects/VHDL/spi_flash/spi_flash_tb.vhd}
    vsim -t 1ps -L altera -L lpm -L sgate -L altera_mf -L altera_lnsim -L fiftyfivenm -L rtl_work -L work -L rsu_test -voptargs="+acc" spi_flash_tb
    add wave *
    view structure
    view signals
    run -all
    As mentioned before, the project compiles ok, but there's the errors above on the simulation. I tried linking and adding both missing files (which are in the /rtl subfolders) to no avail.
    I'm happy to upload the project if that helps you replicate the error.
    Alberto
    KennyT_altera
    Sure, you can attached your design.qar file for me to have a look.
  • AFahr2's avatar
    AFahr2
    Hi Kenny,
    thanks, the file is attached. The main file is spi_flash.vhd, and the testbench is spi_flash_tb.vhd. The .qsys file should be under the rsu/rsu_test folder.
    If you have any questions or suggestions, let me know.
    Albert F.
    KennyT_altera
    Thanks, I manage to look into it.
    Since the design are from qsys, what you need to run is msim_setup.tcl. You may follow the steps below:
    1) Open up the qsys files, generate the simulation model, generate -> generate hdl
    2) Open modesim, cd to directory where the msim_setup.tcl
    source msim_setup.tcl
    3) ld
    4) now the modelsim success run the simulation.
    to include the tb
    5) open up the msim_setup.tcl and modify the top level to spi_flash_tb
    6) make sure your spi_flash_tb.vhd spi_flash under vcom
    7) ld again.
    Let me know if you do not get it,
    • AFahr2's avatar
      AFahr2
      Kenny, thanks for your answer, it took me a while but I got it in the end.
      Just for the sake of completion if anyone runs into the same issues:
      • The msim_setup_tcl file is located under /simulation/mentor
      • I replaced the original testbench file with my "spi_flash_tb.vhd" file on this line: "set TOP_LEVEL_NAME "spi_flash_tb" "
      • I added the following lines under vcom, at the end, in this order:
      eval vcom $USER_DEFINED_VHDL_COMPILE_OPTIONS $USER_DEFINED_COMPILE_OPTIONS "$QSYS_SIMDIR/rsu_test.vhd"
      eval vcom $USER_DEFINED_VHDL_COMPILE_OPTIONS $USER_DEFINED_COMPILE_OPTIONS "$QSYS_SIMDIR/spi_flash.vhd"
      eval vcom $USER_DEFINED_VHDL_COMPILE_OPTIONS $USER_DEFINED_COMPILE_OPTIONS "$QSYS_SIMDIR/spi_flash_tb.vhd"
      Otherwise the test simulation was missing some blocks.
      • Ran the following commands:
      quit -sim
      ld
      and it all seems to compile now. I'll test it for a while now, but it seems the issues I was having are resolved.
      Thanks kindly for your support!
      Cheers,
      Albert F.
      • Stephanie's avatar
        Stephanie
        Hi Albert I'm running into the same issue as you, what does your altera_onchip_flash_block.v look like? Mine is a hex file it seems...
