AFahr2
6 years agoModelsim error on alt_dual_boot and altera_onchip_flash_block - Error: (vsim-3033): Instantiation of 'altera_onchip_flash_block' failed. The design unit was not found.
Hello all, I'm trying to simulate a simple SPI - Flash interface using: Spi_Slave Avalon bytes to packets and Packets to bytes Packets to master Onchip Flash Dual Boot Clk I'm using the Lit...
AFahr2
6 years agoHi Kenny,
thanks, the file is attached. The main file is spi_flash.vhd, and the testbench is spi_flash_tb.vhd. The .qsys file should be under the rsu/rsu_test folder.
If you have any questions or suggestions, let me know.
Albert F.
