Modelsim 10.1 PE syntax error for "tse_10_100_1000_mac" IP core
I have used "tse_10_100_1000_mac" IP core in my design While verifying the design I compiled the tse_10_100_1000_mac IP core to proceed further with verification activity. But modelsim 10.1 PE is reporting syntax error stating "** Error : ../../design/ altera_tse_top_gen_host.v (1) : Syntax error, unexpected non-printable character 0x8b ** Error : ../../design/ altera_tse_top_gen_host.v (1) :Syntax error, unexpected $undefined , expecting class" As it is IP , its files are encrypted and I could not view design file to fix the issue, Kindly let me know how to resolve this issue. Additional Info : Quartus -II 64 bit V13.1.0 ModelSim PE 10.1c Looking forward for solution. Thank you for your valuable time in reading thread.7 Replies
If the simulation model does not exist, the error messages may be issued. Did you use the auto-generated msim_setup.tcl to compile simulation libraries?
Hi kkaibara,
Thanks for your time, I am using my own script to run simulation,I coded it using vsim commands. Apart from this I am using verilog design files of "tse_10_100_1000_mac" taken from IP core directory, files are as mentioned below , 1. altera_tse_reset_synchronizer.v (file size : 3 Kb) 2. altera_tse_top_gen_host.v (syntax error in this file- Encrypted file, Size : 62 Kb) 3. altera_tse_mac.v (file size : 18 Kb) Thanks N.R.M - Altera_Forum
What I did is loading msim_setup.tcl in my custom script like below.
# Triple Speed Ethernet MAC source ./../altera_tse_sim/mentor/msim_setup.tcl set QSYS_SIMDIR "./../altera_tse_sim/" set QUARTUS_INSTALL_DIR "c:/altera/13.1/quartus/" # Compile device library files dev_com # Compile the design files in correct order com Where altera_tse is the name of my TSE IP, altera_tse_sim is the silumation lib folder Quartus II software generated. QSYS_SIMDIR and QUARTUS_INSTALL_DIR parameters are used in the msim_setup.tcl. I have learnt this way from the TSE's testbench. I like that. - Altera_Forum
From your post I could understand that you were trying to simulate TSE's test bench. But I have written design in VHDL and TSE Ip core design files are in verilog, which i compiled successfully except
altera_tse_top_gen_host.v (syntax error in this file- Encrypted file, Size : 62 Kb) I am sharing my batch_run.bat , hoping you will get better clarity on the issue, vlib work vlib design vmap work design vcom -work design -f lib.dgn vcom -work work -f lib.dgn vlog -work work ../../design/altera_tse_reset_synchronizer.v vlog -work work ../../design/altera_tse_top_gen_host.v vlog -work work ../../design/altera_tse_mac.v vcom -2008 -work work -f rtl.dgn vcom -2008 -work work -f tb.dgn vcom -2008 -work work ../tests/IF_FPGA_TS.vhd vsim work.IF_FPGA_TB -l IF_FPGA_TEST.log -do msim.do -c -quiet -t 1ps move IF_FPGA_TEST.log ../logs/IF_FPGA_TEST.log move vsim.wlf ../waves/IF_FPGA_TEST.wlf After running this script compiler is reporting the error. ** Error : ../../design/ altera_tse_top_gen_host.v (1) : Syntax error, unexpected non-printable character 0x8b ** Error : ../../design/ altera_tse_top_gen_host.v (1) :Syntax error, unexpected $undefined , expecting class I have directly copied TSE's design files from quartus TSE directory to my design folder. - Altera_Forum
You must compile all files listed in the msim_setup.tcl to run your custom testbench. They are not only for the TSE’s testbench. This is because altera_tse_mac.v calls many sub-modules in *_sim folder and device specific primitives in Quartus II install folders. You can find the file list in the msim_setup.tcl and can copy them to your script. But the easiest way is calling the msim_setup.tcl in your script as I described before.
If I run your testbench, and if the target device is Arria V, I will do this. vlib work vlib design vmap work design vcom -work design -f lib.dgn vcom -work work -f lib.dgn # vlog -work work ../../design/altera_tse_reset_synchronizer.v # vlog -work work ../../design/altera_tse_top_gen_host.v # vlog -work work ../../design/altera_tse_mac.v # Triple Speed Ethernet MAC source ./../altera_tse_sim/mentor/msim_setup.tcl set QSYS_SIMDIR "./../altera_tse_sim/" set QUARTUS_INSTALL_DIR "c:/altera/13.1/quartus/" # Compile device library files dev_com # Compile the design files in correct order com vcom -2008 -work work -f rtl.dgn vcom -2008 -work work -f tb.dgn vcom -2008 -work work ../tests/IF_FPGA_TS.vhd # vsim work.IF_FPGA_TB -l IF_FPGA_TEST.log -do msim.do -c -quiet -t 1ps vsim -L work -L work_lib -L i_tse_mac -L altera_ver -L lpm_ver -L sgate_ver -L altera_mf_ver -L altera_lnsim_ver -L arriav_ver -L arriav_hssi_ver -L arriav_pcie_hip_ver work.IF_FPGA_TB -l IF_FPGA_TEST.log -do msim.do -c -quiet -t 1ps move IF_FPGA_TEST.log ../logs/IF_FPGA_TEST.log move vsim.wlf ../waves/IF_FPGA_TEST.wlf Please remember necessary files must be placed in proper folders the msim_setup.tcl refers to. - Altera_Forum
Thank you kkaibara , I will check it.
Hi kkaibara,
I am using my own "run.do" file as below (snippet) set ETH_DIR "../TSE_10_100_1000_MAC" vlog -work work ${ETH_LIB}/altera_tse_reset_synchronizer.v vlog -work work ${ETH_LIB}/altera_tse_top_gen_host.v vlog -work work ${ETH_LIB}/altera_tse_mac.v vcom -work work ${ETH_DIR}/tse_10_100_1000_mac.vhd
