11 years agoModelsim 10.1 PE syntax error for "tse_10_100_1000_mac" IP core
Hi, I have used "tse_10_100_1000_mac" IP core in my design While verifying the design I compiled the tse_10_100_1000_mac IP core to proceed further with verification activity. But modelsim 10.1...
11 years agoFrom your post I could understand that you were trying to simulate TSE's test bench. But I have written design in VHDL and TSE Ip core design files are in verilog, which i compiled successfully except
altera_tse_top_gen_host.v (syntax error in this file- Encrypted file, Size : 62 Kb) I am sharing my batch_run.bat , hoping you will get better clarity on the issue, vlib work vlib design vmap work design vcom -work design -f lib.dgn vcom -work work -f lib.dgn vlog -work work ../../design/altera_tse_reset_synchronizer.v vlog -work work ../../design/altera_tse_top_gen_host.v vlog -work work ../../design/altera_tse_mac.v vcom -2008 -work work -f rtl.dgn vcom -2008 -work work -f tb.dgn vcom -2008 -work work ../tests/IF_FPGA_TS.vhd vsim work.IF_FPGA_TB -l IF_FPGA_TEST.log -do msim.do -c -quiet -t 1ps move IF_FPGA_TEST.log ../logs/IF_FPGA_TEST.log move vsim.wlf ../waves/IF_FPGA_TEST.wlf After running this script compiler is reporting the error. ** Error : ../../design/ altera_tse_top_gen_host.v (1) : Syntax error, unexpected non-printable character 0x8b ** Error : ../../design/ altera_tse_top_gen_host.v (1) :Syntax error, unexpected $undefined , expecting class I have directly copied TSE's design files from quartus TSE directory to my design folder.
