15 years agomin max frequency requirement of altera IP components
Hi all, I have modified the standard project provided by the cycloneIII_3c120_embedded so that some of the components work at a lower frequency. Unfortunately while the project synthesizes with...
15 years agoThe table JacoL suggested should be considered only a reference for performance, I'd say an asyntotic upper limit.
There are a lot of factors affecting the 'real' fmax you can attain. Mainly: - how much fpga resources are used - how much resources are available for routing - how much you are smart in placing timing constraints For example, I've been told (and I've quite verified it) that on a Cyclone III device you can't expect to safely use Nios/f core at a frequency above 100-120 MHz, unless your fpga is almost empty and you thoroughly check the timings after every recompilation. Regarding the lower frequency limits I don't know. I think this depends from pll minimum operating frequency.
