18 years agoMegacore functions in DSP Builder not working
Hello, I'm having problems using the MegaCore functions with Matlab's Simulink. All the other blocksets work but when I try to use MegaCore functions under the Altera DSP Builder Blockset the block a...
18 years agoOK, so this is the full story for future readers of this thread.
For versions prior to version 8.0 of the Quartus tools design suite. To be able to install DSP Builder you need to install the following first. Quartus II Tools. MegaCore IP Libraires. ModelSim-AE (if you wish to use ModelSim from within the DSP Builder environment). MathWorks Matlab tool (compatible release version of tools) Simulink Tools then you can install the DSP Builder tools. For version 8.0 Altera tools and moving forward through ?? unknown version; Quartus II and the MegaWizard IP libraires are installed at the same time. All the rest of the above info remainds valid. I hope this helps. You also need to have a valid License extension for the DSP Builder tools. Avatar
