9 years agoMegaCore Function Generation Error
I got an error using the example file "topfft.mdl" in HIL tutorial offered by Altera. When I open the"fft_stream" FFT control window and click on "Step 2: Generate" to update the FFT megacore function, error prompts out as follows: "MegaCore FUnction Generation Error" "IP Functional Simulation Model Creation Failed. Code==3". My running enviroment is "DSP builder 16.1" and "Matlabe2015b" How can I solve this problem? Hou1 Reply
Have you tried running "alt_dspbuilder_refresh_megacore" on the command window?
