MCDMA/PCIE max number of channels - how to get 256 physical channels
I'm sorry for the long delay but as we went with a workaround which was to use 64 channels, we were able to move forward. Still we will try again with project you sent when time permits.
I have looked at the package you sent and I have a couple of notes: 1) contains Stratix 10 target whereas we use Agilex, so IP had to be upgraded, which was successful; 2) Settings did not include CVP which is how we load the design - presumably not a problem; 3) We need to provide PCIE pinout to try in our eval board; 4) Design does indeed use 256 channels and I noted that the test report indicated it was 100% successful when configured for more than 64 channels, up to 256 channels - we will try again from our end when time permits and open another thread if necessary.
Thank you for your support. You were very helpful.
Greg
