MCDMA/PCIe - what is frequency of coreclkout_hip?
- 3 years ago
I think that indicates the Clock Fmax.
If you changed the optimization Mode from Balanced to Aggressive Area you can achieve the 500MHz.The Fmax specification is based on the fast clock used for serial data.
The interface Fmax is also dependent on the parallel clock domain which is design dependent and requires timing analysis.
Hope this clarified.Regards,
Wincent_Intel
Hi Wincent,
I used the example design provided in Quartus. Running PIO transfer, gencheck, loopback seem OK.
Then, I want to insert our accelerators to receive data from the HOST, doing computations, and send back results to the HOST.
I want to run these accelerators at a lower frequency (200MHz), so I pulled PLL core which uses coreclkout_hip as the reference clock.
But when re-checking TA clock report, it showed the output clock freq = 400 MHz and refclk = 500 MHz
@Wincent_Altera wrote:Can you check if you enable two clock together ?
Could you clarify this? I could not see where to enable two clocks when pulling the MCDMA IP Core.
There is only 1 selection regarding frequency: "PCIe gen3 x8 - 250 MHz"
TN
Can you please provide me the printscreen of the TA report that mentioning 500 MHz ?
Wincent_Intel
- bibo3 years ago
Sure! This is the PLL configuration
And the system view with clock interfaces
And this is what clock report with the final snapshot
- clkout of the IOPLL
- And clock network report
TN
- Wincent_Altera3 years ago
Wincent_Intel
- bibo3 years ago
Thanks for your clarification.
So, how could I review the actual clock frequency?
TN
