9 years agoMAX10 Development kit LVDS TX assignments
I'm currently using the MAX10 development kit, and I'm trying to interface with two external components. In order to have a stable clock circuit, I use the "external" clock source on the MAX10 De...
9 years agoYour path looks fine to me. But it looks like those HSMC_CLK_OUT outputs take a straight shot to the HSMC connector. Do you have anything plugged into the HSMC slot that terminates the clocks? LVDS doesn't work very well when not terminated.
If you can't terminate the clocks then try a single-ended output standard, such as LVCMOS. LVCMOS should be able to run at 50MHz no problem.
