8 years agoMAX10 ADC Core Channel Sequence Issue
Hi All, I am having a small issue with the ADC Core-only IP. I have two channels enabled (11 and 12) and a controller that sequences between them: Once 11 is converted, it starts 12, then 11,...
8 years ago --- Quote Start --- OK, that's really weird. As the timing diagram shows, are you seeing the command_ready signal at the end of the t1 time (with no response yet; response_valid is low) when you first access the first channel? --- Quote End --- Yes, everything looks like it is working as expected other than the response_data being for a different channel than response_channel shows. Unfortunately time is short, so I have been asked just to register the command_channel and correct the address that way. Thank you for taking the time to think about it. If I get some more time I will cycle back on it and see what I can figure out.
