8 years agoMAX10 ADC Core Channel Sequence Issue
Hi All, I am having a small issue with the ADC Core-only IP. I have two channels enabled (11 and 12) and a controller that sequences between them: Once 11 is converted, it starts 12, then 11,...
8 years agoOK, that's really weird.
As the timing diagram shows, are you seeing the command_ready signal at the end of the t1 time (with no response yet; response_valid is low) when you first access the first channel?
