8 years agoMAX10 ADC Core Channel Sequence Issue
Hi All, I am having a small issue with the ADC Core-only IP. I have two channels enabled (11 and 12) and a controller that sequences between them: Once 11 is converted, it starts 12, then 11,...
8 years agoSorry, I think I somehow missed that you were getting the opposite voltage measurement for the two channels.
There's still latency for when a value becomes available, but yes, the voltage should correspond to the appropriate response channel. Any chance you accidentally have the analog input pins swapped?
