8 years agoMAX10 ADC Core Channel Sequence Issue
Hi All, I am having a small issue with the ADC Core-only IP. I have two channels enabled (11 and 12) and a controller that sequences between them: Once 11 is converted, it starts 12, then 11,...
8 years agoI can try that.
I am really confused by "response_valid", "response_channel", and "response_data". Based on what I am reading in the User Guide, when response_valid goes high that data on response_data will correspond to the response_channel. I don't see how a latency issue (command_valid is held high, and I simply increment the command_channel when command_ready is asserted - all I control is command_channel, nothing else) could cause response_data to be for a channel other than response_channel...
adc_inst : component adc_core
port map (
clock_clk => clk10,
reset_sink_reset_n => '1',
adc_pll_clock_clk => clk10,
adc_pll_locked_export => pll_lock,
command_valid => '1',
command_channel => adc_command_channel, -- Set this on adc_command_ready
command_startofpacket => '0', -- Unused on ADC core
command_endofpacket => '0', -- Unused on ADC core
command_ready => adc_command_ready,
response_valid => adc_response_valid,
response_channel => adc_response_channel,
response_data => adc_response_data
response_startofpacket => open, -- Unused on ADC core
response_endofpacket => open -- Unused on ADC core
response_valid, response_channel, and response_data are just signals used for the Signal Tap LA. adc_command_channel is incremented when adc_command_ready goes high. I have tried delaying the reset and command_valid signals several thousand clock cycles after pll_lock goes high, but this did not make any difference. The control is so simple, that even if I am dealing purely with a latency issue the only way I see around it is to either keep track of which channel is really getting reported from the ADC, or just convert each channel twice. Doing a double conversion is not desirable because it would cut our sampling rate in half.
