OCphy
5 years agoMAX 10 Ethernet SFP Solution
Greetings.
I would like to use the MAX 10 FPGA in an design which requires Ethernet connectivity. Can I implement a Cu SFP to connect the Ethernet to the FPGA?
I have reviewed the Triple Speed Et...
- 5 years ago
Thanks Rex for the explanation.
Just to top up further on Rex input here.
Yes, different FPGA product family may have slightly variance of different TSE IP support feature.
I looked at the TSE IP in Max10 and it only support Ethernet MAC and none of the physical layer.
- Max 10 TSE MAC IP only expose GMII or RGMII interface to be connected to external PHY chip
- Whether the external PHY chip can be connected to SFP port or not will depends on the external PHY chip capability
dlim
Deshi_Intel
5 years agoAlright, good luck in your project development.
For now, I am setting this case to closure.
Feel free to file new forum thread if you have new enquiry in future.
dlim
