MAX 10 Ethernet Error
Hi Friends
- Deshi_Intel
From your signal_tap debug, that means it doesn't detect any assertion of ff_rx_sop signal. Nothing is coming out from TSE MAC Rx to FPGA core logic
- It's either something is already corrupted from PHY Rx to FPGA Rx side
- or some issue with your signal_tap sampling clock (fpga_mii_tx_clk)
You can set signal_tap trigger condition to "don't care" stage instead of trigger rising edge
Also you can probe TSE rx_err[5:0] to try identify what kind of error that you are facing
Another common debug approach is to enable TSE internal loopback to isolate whether the issue is inside FPGA or outside on your board setup
dlim
- Deshi_Intel
We do not receive any response from you to the previous question/reply/answer that I have provided in Feb.
This thread will be transitioned to community support.
If you have a new question, feel free to open a new thread to get the support from Intel support agent. Otherwise, the community users will continue to help you on this thread.
Thank you.
dlim
