17 years agoMatlab FFT Vs. DSP Builder FFT
I'v posted a thread in this section, maybe I was wrong, please check it at the following link http://www.alteraforum.com/forum/showthread.php?t=1654&highlight=dsp+fft (http://www.alteraforum.co...
17 years agoHi again,
in those days I tried to adjust last things and also to recreate the input signal with an IFFT. On the file I posted some time ago, I tried to adjust the FFT amplitude that was less then the Matlab one. I found some trouble with the exponent value again. I will post the text where it speaks about the FFT scaling. " the exponent records the number of left or right shifts used to perform the scaling. asa result, the output magnitude relative to the input level is:
output*2-exponent
for example, if exponent = –3, the input samples are shifted right by
three bits, and hence the magnitude of the output is output*2^3 " To scale I shifted the real and imaginary output. I found a negative exp so a made a right shift as the example. But... The result is that everything turns really good when I not scale the real and imaginary output. It seem to be futile to scale it! Also when I try to recreate the input signal with the IFFT everything is good without the scaling.... ..mmm i missed something? I will post the new scheme that bypass the scaling. http://img147.imageshack.us/img147/8247/fftsitosc7.jpg
