LVDS SERDES IP with cascaded downstream PLL
- 5 years ago
Hi Michael
Thanks for your inquiry.
In general, we don't use output clocks from LVDS SERDES IP as the purpose to cascade another PLL. Are you creating your design using Platform Designer?
In Platform Designer, I don't see a valid connection from output clocks of LVDS SERDES IP to the adjpllin of the cascaded PLL, in fact, the connection from cascade_out of an upstream PLL to the adjpllin of downstream PLL is available.
Eng Wei
Hi Michael
Eng Wei
- MichaelB5 years ago
Hi! Thank you for your reply!
Yes I was using the platform designer. I just thought I can connect a downstream PLL due to info in SERDES LVDS IP that a downstream PLL should have High Bandwidth setting. I assumed I can connect an additional outclk to adjpllin and the locked to the permit_cal signal (like general IO PLL cascading).
Now I have created an external PLL which is connected to the LVDS SERDES block and use a cascade-out from external PLL for my downstream PLL.
Using this connection there is no critical warning in my design and fitter result shows all clocks which I have configured.
Michael
- EngWei_O_Intel5 years ago
Hi Michael
Great that the issue is going away and I hope this suit your design needs. I am currently transitioning this case to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
Eng Wei
