LVDS SERDES IP no DPA lock in simulation
- 5 years ago
I figured out what the issue was:
I used the example design simulation as a comparison and eventually saw that the example locks only after over 8 us. This seems way longer than what the lock time specification in the device datasheet is specifying.
I then ran my own simulation for that long (before I had only run it up to 4 us as according to the lock time specification that is way more than should be needed) and it does also lock.
I am posting this in case someone else ever runs into this issue.
Thanks for the help along the way.
I just realized you may mean that when you run the simulation you don't get waveform data for the signal rx_dpa_locked. I don't know why this would be when I run the simulation I do get data for that signal but it is always low. See attached screenshot.
