GiladA
2 years agoLvds load enable
I design LVDS SERDES IP of 700Mbps Data Rate with external PLL and Serdes factor of 8 on Stratix 10. In the lab i test the design with external loop and encounter a problem with the lsb in the RX (...
- 2 years ago
suggested PLL-parameters are displayed in parameter editor for SERDES IP. Expect -45° (-360/8) load_enable phase shift for 8 bit SERDES.
FvM
2 years agoHi,
there's also a phase shift required for load_enable clock.
Question is however, how are you synchronizing LVDS receiver with source?
- GiladA2 years ago
Hi
the source and receiver are clock freq synchronize, so i use DPA block to synchronize.
what is the phase shift required for load_enable?
is it correct to define low freq (87.5MHz in my case) and duty cycle of 12.5?
Thanks Gilad
- FvM2 years ago
