14 years agolpm_hint
Hi all! Many of Altera's 'Library Parametrizable Modules' (LPMs) have a 'lpm_hint' generic. This parameter is a string that is parsed, and can contain an arbitrary long list of parameter/valu...
14 years agofor anything you cannot find, or get a reply to here, I suggest opening a mysupport case.
The megafunctions are quite old in some cases, and in most cases have to support a wide range of devices, hence the wide range of parameters. So parameters keep getting added, when usually its usually better to let the synthesisor do most of the work picking paramters.
