18 years agoLPF filter
Hi everyone, i have to make an operation of filtering, in particular i need to implement a low pass filter working in a range of frequency from 0 to 50 khz; i tried to use FIR compiler tool to gen...
17 years agoEverything seems correct from what you write.
Anyway, just a couple of clues: 1) Have you used 500kHz sampling rate also for the NCO output? 2) Are you using an excessive output truncation factor which may hide the filtering effect?
