Low latency Ethernet 10R Reference Design. How to modify the behaviour of the testbench?
Hi Deshil,
Sorry for not answering earlier. I solved now all my hardware issues with my version of PHY connected to the INTEL MAC. Thanks for that.
I found several UG's and AN documents describing the PCIexpress IP and Examples. At a certain moment in time, i managed to generate a .par file, from which QUARTUS lite 18.0 generated PCIE- IP. However, i cannot find a way to generate the <pcie_a10_hip_0_example_design> as described in ux-dex-a10-pcie-avst.pdf, found at https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug-dex-a10-pcie-avst.pdf.
Can your PCI Express collegue support me in generating this design example. Second question to him: there is a choice between the avalon-st protocol implementation, and a avalon-mm implementation. As the Low Latency MAC interfaces with an Avalon-ST interface, I thought this would be the more easy choice. Is that right, or are there reasons to use the mm version? Regards, Pieter
