CosmoKramer
2 years agolocal_reset_done and emif_usr_reset_n on emif ip
Could someone please help me understand difference and relation between these two signals on the emif ip - local_reset_done and emif_usr_reset_n ? If I toggle local_reset_req to the ip, then local_r...
AdzimZM_Altera
2 years agoHi,
emif_usr_reset_n is an active low signal.
It's asserting when entering reset sequence then perform calibration.
local_reset_done is a active high signal.
It's asserting when the calibration is done.
According to the initialization flow, the memory will run a calibration first before it's able to accept command from user logic.
Therefore, the emif_usr_reset_n should be trigger first.
Adzim
- CosmoKramer2 years ago
Just to make sure i understand it correctly, please confirm:
1) after user issues reset_request, which of the two signals go high first:
emif_usr_reset_n
local_reset_done
2) When these signals go low to high, it means that IP is out of reset. is that right?
thank you.
