13 years agoJPEG Compression
HI
am using IP core from opencores.org : JPEG Encoder core facing this issue : # ** Error: (vcom-7) Failed to open design unit file "../design/common/JPEG_PKG.VHD" in read mode.# can any 1 solve this issue !!! thanks in advance !!!!1 Reply
This error means that modelsim doesn't find that file. You should check that you have all the required files and that they are at the correct place.
