13 years agoJPEG Compression
HI am using IP core from opencores.org : JPEG Encoder core facing this issue : # ** Error: (vcom-7) Failed to open design unit file "../design/common/JPEG_PKG.VHD" in read mode.# ...
13 years agoThis error means that modelsim doesn't find that file. You should check that you have all the required files and that they are at the correct place.
