JESD204b -- How Many Device Clocks
I am specifying an FPGA module that implements an JESD204b interface with an Arria 10 device. I have 4 each ADC devices that have 2 serial data lanes each (16 lanes total). The transceiver blocks on the FPGA come 6 per block. The puzzle is:
1. How many transceiver blocks will I need to use ?
2. Will I need to run an individual JESD204b Device Clock from the device-clock/sysref management circuit to every blocks clock reference pin or can one device clock be distributed on the "xN" internal Arria 10 clock network ( or some other method)?
3. Maximum Serializer/Deserializer frequency is expected to be below 6 Gbps.
- Kshitij_Intel
Can you please share the exact OPN or which dev kit you are using?
Thank you
Kshitij Goel
- Kshitij_Intel
Please go through the AN 803: Implementing Analog-to-Digital Converter Multi-Link Designs with Intel® Arria® 10 JESD204B RX IP Core
Thank you
Kshitij Goel
- Kshitij_Intel
We do not receive any response from you to the previous reply that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
Thank you
Kshitij Goel
