Issue with Simulation Stalling in Intel P-Tile Streaming PCIe Gen4 x8 Example Design
- 1 year ago
I am Wincent, Application Engineer from Altera.
We sincerely apologize for the inconvenience caused by the delay in addressing your Forum queries.
Due to an unexpected back-end issue in our system, your Forum case, did not reach us as intended.
May I know which Questasim version that you are using?
There is an known issue we try to fix for the P-tile simulation tools.
To work around this problem, use Siemens* Questa Sim-64 2022.2. Starting in the Intel® Quartus® Prime Software version 23.3, solve this issue by adding this command " set USER_DEFINED_ELAB_OPTIONS "-voptargs=\"-noprotectopt\" before running simulation in the Siemens* Questa Sim.
Detail you may refer to https://www.intel.com/content/www/us/en/support/programmable/articles/000092901.html
Hope that is able to help you to move forward,
Wincent_Intel
- Is there any way to reduce the overall simulation time?
- For F-tile we do have a FastSIM mode https://www.intel.com/content/www/us/en/docs/programmable/683140/22-4-8-0-0/fastsim-mode-support.html . but the features is not available to P-tile
- Did you add all signal to the simulation model ?
- If you need a faster simulation completion time, perhaps you can add few only signal that you need to monitor for example pin_perst, ltssm, gen speed/width and other pcie related signal.
- What processes are running in the background before the 126725 ns mark?
- I think the background process is written in the scripts of simulation. Other than that we do not have specific indicator to shows that.
- Is there any documentation available that explains the activities happening during this period?
- Is there any specific reason you need to know what happen ?
Wincent
Hi wincent,
1.Is there any specific reason you need to know what happen ?
Yes Understanding from Link Training and Process Flow
Can you explain how the process starts for link training in the code and how and where the subsequent tasks are called in the BFM for both the Root Port (RP) and Endpoint (EP)? I’d like to understand how the process begins and progresses
2.When using the option set USER_DEFINED_ELAB_OPTIONS "-voptargs=\"-noprotectopt\" in msim_setup.tcl:
- If I run ld_debug and run -all, it takes 4.5 hours to reach the log message: INFO: 126725 ns RP User Avmm Driver: begin RP Configuration, and the simulation finishes after 4.5 hours.
- If I use ld and run -all, it takes 40 minutes to reach the same message INFO: 126725 ns RP User Avmm Driver: begin RP Configuration, but the simulation seems to get stuck afterward with no further logs waiting for the wait_request signal to deassert from the Root Port BFM..
What could be causing these differences, and how can I ensure smooth simulation without getting stuck?
3.Warning About Optimizations
When running msim_setup.tcl and ld_debug I get this warning:
Warning: (vopt-10587) Some optimizations are turned off because the +acc switch is in effect. This will cause your simulation to run slowly. Please use -access/-debug to maintain needed visibility.
How can I avoid this warning while maintaining necessary visibility without impacting simulation performance? Could this warning be related to the delays I’m experiencing?
4. Reset_status_n Signal Delay
In the simulation waveform ,One observation is the p0_reset_status_n signal remains low for approximately 100,000 ns, which seems to delay progress. Are there any adjustments or optimizations to reduce this reset assertion time? Could this be the case delay I’m experiencing?
- Wincent_Altera1 year ago
Hi
Can you explain how the process starts for link training in the code and how and where the subsequent tasks are called in the BFM for both the Root Port (RP) and Endpoint (EP)? I’d like to understand how the process begins and progresses.
>> The exact flow does not stated clear in user guide, But I try to explain as much as I could referring to my understanding toward PCIe system. It might not be exactly same as P-tile PCIe , but I believe the fundamental would be the same. Those are for your reference purpose, please correct me if you think I am wrong.
>> The link training process begins with the power-up and reset of both the Root Port and the Endpoint. This is managed by the power management and reset control logic of the system. Once powered up and out of reset, the Root Port initiates the link training process by sending a series of training sequences, known as TS1 and TS2, to the Endpoint. These sequences are used to negotiate the link parameters, such as link width and speed.
>> The Root Port then enters a polling state, waiting for the Endpoint to respond with its own training sequences. During this phase, the Root Port and Endpoint exchange information to agree on the link parameters. Once both sides have agreed on the parameters, they transition to the "Link Up" state, indicating that the link is trained and ready for data transfer.
>> On the Endpoint side, after power-up and reset, it waits to receive the training sequences from the Root Port. Upon receiving these sequences, the Endpoint responds with its own training sequences. This exchange continues until both the Root Port and Endpoint agree on the link parameters. Once the negotiation is complete, the Endpoint also transitions to the "Link Up" state.
>>In a BFM, this process is typically modeled using a series of tasks and functions that simulate the behavior of the Root Port and Endpoint. For the Root Port, an initialization task handles the power-up and reset sequence. This is followed by a link training task that sends the training sequences to the Endpoint and waits for a response. Once the link training is complete, a link up task is called to indicate that the link is ready for data transfer.
>> Similarly, for the Endpoint, an initialization task handles the power-up and reset sequence. A link training response task is then called to respond to the training sequences sent by the Root Port. Once the negotiation is complete, a link up task is called to indicate that the link is ready for data transfer. The sequence of calls in the BFM typically starts with the Root Port initialization, followed by the link training and link up tasks. The Endpoint follows a similar sequence, starting with initialization, followed by the link training response and link up tasks. This ensures that both the Root Port and Endpoint are synchronized and the link is properly trained and ready for data transfer
>> Following our user guide https://www.intel.com/content/www/us/en/docs/programmable/683038/24-1-9-1-1/running-simulations-using-questasim.html>> we are suggested to use ld_debug, using "ld" only could potentially cause malfunction.
>> aside of the warning, do you see any error code raise up ?
>> those warning can safely ignored. However I suggest you to try out Quartus v24.3 , I believe we have better optimization on it. let me know if you still seeing the same issue
>> I do not experience the same before, perhaps you can check your .v file code and see if you can toggle the p0_reset_status_n signal assertion or not.
>>Check the logic that controls the p0_reset_status_n signal. Ensure that the conditions for deasserting the reset are met as soon as possible. Look for any unnecessary delays or conditions that might be keeping the reset asserted longer than needed. Ensure that the reset signal is properly synchronized with the clock domain it is associated with. Improper synchronization can cause metastability issues, leading to longer reset times.
Wincent- thanavignesh1 year ago
Hi wincent,
1.In the provided snippet from the Endpoint, the ref_clk0/1 and coreclkout_hip signals appear to be functioning correctly, and the pin_perst_n along with other reset signals asserted as expected during initialization. However, the p0_reset_status_n signal, an output of the PCIe Hard IP core, remains deasserted, and we lack visibility into the internal logic driving this signal. Are there alternative methods to control or debug the behavior of the reset_status signal?
2.Additionally, what is the typical simulation runtime for the P-Tile example design configured for 4x8 operation with default settings when using Questa 23.4 or other supported versions?
Thanavignesh- Wincent_Altera1 year ago
>> Reset_Status_N is active-low signal is held low until pin_perst_n has been deasserted and the PCIe* Hard IP has come out of reset. This signal is synchronous to coreclkout_hip. When port bifurcation is used, there is one such signal for each Avalon® -ST interface. The signals are differentiated by the prefixes pn. This is a per-port signal.
>> May I know if you hit the timing clean ? timing fail could potential cause the signal to be fail.
>> Just double confirm, it is example design generated from the ip catalog right ? Could you please share with me your .ip file ? so that I can try to replicate this on my place.
>> If you grab all signal , the simulation time will be around 3-6 hours.
>> if certain signal only, it will be less than 1-2 hours.
Wincent
