Issue with Connecting Intermediate Output to ALTDDIO_IN Input in FPGA Design
Hi Adzim,
Thanks for your response. Our actual production code is running on Quartous Prime 19.1 standard edition but this demo code is running on Quartous Prime 20.1 edition. In our Production device we are using cyclone V 5CEBA4U15C7 device. In our design we are using ALTDDIO_IN ip. Analysis and synthesis stage it is failing.
Thanks & regards,
Sameer
- FvM2 years ago
I think the error message is rather clear. DDIO_IN is expecting input from IO-pin but you are connecting it to a register. If actually need DDR register function in fpga fabric, you build it from registers.- Sameer-sahu2 years ago
But if we want to double the data rate of an intermediate value, then how to use this IP in our design. We are debugging something. So we attach some intermediate value as input to DDIO_IN. Can you please suggest, how to double the data rate of intermediate registor value.
- FvM2 years ago
DDIO_IN does not double a data rate. It splits a double data rate stream into two single data rate streams as shown in my previous post. Please explain in detail what you want to achieve.
