Sameer-sahu
2 years agoIssue with Connecting Intermediate Output to ALTDDIO_IN Input in FPGA Design
Hello everyone, I'm currently working on an FPGA design project and have encountered a problem that I hope to get some guidance on. The issue arises when trying to connect one of our intermediate ou...
AdzimZM_Altera
2 years agoHello Sir,
I'm Adzim, application engineer will assist you in this case.
I require some information in the points below to debug this problem:-
- Which Quartus version that you're using?
- Which FPGA device that you're using?
- Can you provide the IP name as in Platform Designer/Quartus?
- Which compilation stage is failing?
Adzim
Adzim
- Sameer-sahu2 years ago
Hi Adzim
Thanks for your response. Our actual production code is running on Quartous Prime 19.1 standard edition but this demo code is running on Quartous Prime 20.1 edition. In our Production device we are using cyclone V 5CEBA4U15C7 device. In our design we are using ALTDDIO_IN ip. Analysis and synthesis stage it is failing.
Thanks & regards,
Sameer
