fa_fpga_enthusiast
1 year agoIssue with BSP Creation for Nios-V/m Using LPDDR4 on Agilex-5 (Quartus 24.1 & 24.3.1)
Hello, We are encountering an issue while creating a BSP for the Nios-V/m targeting Agilex-5 using LPDDR4 as the processor memory. We have attempted this using Quartus 24.1 and 24.3.1 but faced the ...
tehjingy_Altera
1 year agoHi
Yes. I am using 24.3.1.
I have removed the on chip memory and only with the emif and was able to generate the BSP.
When you add in the memory device you would need to add in the same name as the name mentioned in the PD.
If you memory device name contains the suffix "_windowed_slave" you would need to add in the suffix, if not you do not need to add it in.
Jingyang, Teh
