13 years agoIs the Standard Blockset outdated?
Hi there! To get started with FPGA development I just read through the DSP Builder handbook PDFs. In there it said that the Standard Blockset shouldn't be used anymore: --- Quote Start --...
13 years agoAltera doesn't recommend Standard Blockset for new designs but has not announced that it will be removed. It won't be removed without prior notice so you can definitely expect it to be around in the next release.
As you say, there are features in Standard that aren't in Advanced. If you see no way to design without these then you will have to use Standard blockset, but it's recommended that the parts of your design that can use Advanced blockset should do. At some point I would expect some of those features to migrate to Advanced blockset.
