GZsch
6 years agoIs the CKE port for the INCLOCK or the OUTCLOCK?
My device is an Arria 10 SOC. I'm using the GPIO Intel FPGA IP 18.0 core, set up as DDIO with separate input/output clocks. I'd like to use the clock enable (port), but I don't see whether that enabl...
EBERLAZARE_I_Intel
6 years agoHi,
For the GPIO input registers, the input I/O transfer will likely fail the hold time if you do not set the input delay chain.
For more info please read the Timing Closure Guidelines:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_altera_gpio.pdf#page=21
SZack
6 years agoHi,
This last reply did not really address the question which is "should the clken port be driven synchronously by the clkin or clkout clock?". Can you please answer that question?
Steve Zack (the FAE supporting this customer)
