9 years agois it possible to transmit 1080p30 using the SDI II IP core?
I am using the SDI II IP core in triple-rate (SD/HD/3G) transmitter mode with a 148.35 MHz reference clock. Video timing is generated by a clocked video out IP core . When I set the tx_std input of...
9 years agoThe example design will tell how to transmit HD-SDI data to the SDI II IP Core. I think the data valid could be 1 high and 1 low to make the parallel data band width 50% against 3G-SDI. BTW, the reference clock would be 148.5 MHz if you want to transmit 30 or 60 fps video format.
https://documentation.altera.com/#/link/smx1471929114447/cca1471930964574
