1 Reply
- Wincent_Altera
Hi yamasan ,
Based on my understanding , SDI II FPGA IP is compatible with showing on-screen text on SDI output, but it does not generate or compose the text by itself; you need to add separate text/overlay composition logic in the video path before the SDI II transmitter, and then the SDI II IP will transmit the already composited video stream.
Wincent_Altera
