IP upgradation error in QPP v 23.4 for altera_emif DDR4
- 2 years ago
Thank you for submitting your question in Intel Community.
I'm Adzim, application engineer will assist you in this case.
The Row address width of 12 is no longer available in current Quartus edition due to the memory longevity.
Please select a value suitable for your memory component that available in the IP parameter editor.
Adzim
I'm not receiving any feedback from you since my last reply.
I wonder if your issue has been addressed.
Please let me know if you have any further question in this thread.
Adzim
- back-bencher2 years ago
Pardon for the late reply. Actually, I tried removing the IP from the project and again do the compilation. The compilation fails at the Plan stage. When I investigate, it is because of some other IP. Now I re-did the copy option and upgraded the IP before it produced the aforementioned error. While including the same IP, again the compilation fails at the Plan stage.
Reason seems to be a register in some other IP, which is having synthesis attribute as follows:
(* altera_attribute = {"-name MAX_FANOUT 1; -name ADV_NETLIST_OPT_ALLOWED ALWAYS_ALLOW"}*)
I found the reason in the failure log of QPP.
