Ip-make-ipx command issue
Hi Team,
I have upgraded design from 13.0 to 22.1 , (device upgraded from cyclone III to cyclone v gx). I tried regenrate the .ipx file in 22.1 but in nios ii command shell , i am getting error as command not found. PLease give guidance to resolve this issue.
- EBERLAZARE_I_Intel
The design version is too old, is it possible if you create the design in the new Quartus based on the old Quartus?
- SERMASWATHIKA
Contributor
Hi ,
Yes,i have upgraded the design from 13.1 to 22.1 whichevere ip could be upgrade i did. so i am trying to generate the ipx file for this version. is that mandatory or not?
Can you try go to Platform Designer > "Tools > Option" and add the IP search path in which the .ipx file located.
- SERMASWATHIKA
Contributor
i have tried with ip-make-ipx.exe command, now it is working.
Thanks for the update.
I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
