18 years ago
IP Altera FIR filter 6.1 multiple coef set problem
Hi!
I created a FIR filter using Altera FIR IP v.6.1 (and Quartus v6.1).
The characteristics of my filter are:
-Rate specification : Decimation : 8
-Number Of Input Channels : 1
-Input Number System : Signed Binary
-Input Bit Width : 12
-Output Specification : Based On Method : Bit Width Only Full Resolution
-I enter two different coefficient sets with 32 coefficients each
-Coefficients Scaling Auto Bit Width 8
-Device Family : Stratix II
-Structure : Distributed Arithmetic : Fully Parallel Filter
-Pipeline Level : 1
-Data Storage : Logic Cells
-Coefficients Storage : Logic Cells
The problem is : the filter takes only the first coefficients set whatever the signal ("1" or "0") at the input "coef_set" of the filter.
I tried to create the same filter in Single Rate and it works well.
Why the coef_set selector does not work with Decimation?
1 Reply
    I would stay away froim the version 6.1 version fo the FIR compiler.
    I cannot say for sure, but I think that I recall reading about lots of issues with this compiler (in that version).
    Upgrade to the latest tools (or at least 7.2) and see if the issue goes away.
