16 years agoAgain I don't know about your set-up and IP signals. But the role is 1:100.
It is your responsibility to clk data in at 1/100 of output rate. Then it is the responsibility of CIC IP to give you the correct output. One way is this enable at a rate of 1/100, connect to valid_in: -- detect the edge of slow clk in the fast clk domain: wait until fast_clk = '1'; clk_1d <= clk_in; clk_2d <= clk_1d; enable <= clk_1d and not clk_2d; edit: make sure clks are synchronised
