9 years agoInternal Oscillator for MAX10 device
Hello. I am trying to use internal oscillator in MAX10 FPGA. It works but I am getting 83 mhz instead of desired 55 mhz. Already confusing the frequency setting in IP altera_int_osc. It says C...
9 years agoYou don't get a choice. The internal oscillator for the smaller MAX10 devices is spec'ed to be in the range of 55MHz to 116MHz, nominal 82MHz. Your oscillator is more or less on spec as typical at 83MHz.
If you need a repeatable, accurate frequency source, then you need to use an external source based on a crystal, and possibly feed it to a PLL internal to the MAX10. The internal oscillator is provided as a 'freebie' but you don't get to choose the value, you only know is is between 55MHz and 116MHz, and may change widely over voltage and temperature.
