yt_liu
6 years agoInterfacing the DSP IP cores with Nios ii processor using Avalon-ST
I have successfully built a microphone signal filter using the CIC and FIR DSP IP cores, and now I want to store the output of the FIR filter to a Nios ii processor's main memory. I'm doing this in o...
- 6 years ago
Thanks for your update. Sorry as I am not really a design expert and could not really comment on the right memory IP to use. However, depending on the size of memory required, you can explore into normal FIFO, on-chip memory ie ROM/RAM and also DDR IP. Note that you would still need to create some glue logic to perform the conversion on your own.
Chee Pin
CheepinC_altera
6 years agoIt is recommended for your to try to create simple test design and run through functional Modelsim simulation before you proceed to hardware test to help ruling out functional related issue.
