jsondergaard
3 years agoIntel FPGA Avalon I2C (Host) Core
Does anyone have an example or tutorial on how to use this core on an SoC? I have had success with the Cyclone V using other cores and writing to their registers from the HPS via the Avalon mm to suc...
- 3 years ago
The register addresses in the datasheet actually need to be multiplied by four. Everything is working just fine now.
jsondergaard
3 years agoEberlazare,
I appreciate the suggestion. This appears to be a different core than the "Intel FPGA Avalon I2C (Host) Core." It is also meant for a MAX 10 dev kit, so the hardware isn't quite the same. I probably should've mentioned that I am using the DE10-Nano from Terasic. With that said, the general Qsys connections I have on my end are relatively the same.
Thank you,
Jordan
- jsondergaard3 years ago
