SERMASWATHIKA
Contributor
2 years agointel early pin assignment
i have tried to generate pin report for dummy design as whole design completion takes time. when i tried to assign epcs pins to design pins, it is not accepting and showing error as dedicated pins ca...
FakhrulA_altera
2 years agoHi SERMASWATHIKA,
Based on my understanding you won't need to assign the pin manually, dedicated pins are typically assigned through the pin planner or assignment files in the Quartus. May I know specifically what are you trying to achieve?
Fakhrul
