JET60200
Contributor
6 years agoINtel Design Store "A10SOC Scalable Multispeed 10M-10G Ethernet Design" fails to test in system console ?
Hello, I have an A10SOC Kit Board. IN intel design store, I found a Multiple - Rate 10GE design example on A10SOC Kit Brd as below link : https://fpgacloud.intel.com/devstore/platform/16.0.0...
- 6 years ago
after following the design user guide ( https://www.intel.com/content/dam/altera-www/global/en_US/uploads/3/38/Arria_10_SOC_Scalable_Multispeed_10M-10G_Ethernet_Design_user_guide.pdf ),
to set " U50 CLK0A/B = 100MHz for "mm_clk" input ", the System Console can work as expect, I can run test using this example design on A10SOC KIT Board,
Thanks all for helps.
Deshi_Intel
6 years agoHi Jet,
User guide doc is meant to provide instruction steps to guide user on how to use the example design only while your question is more towards design implementation side.
Unfortunately there won't be any doc to describe on low level reg control for design implementation.
- It's expected for user to slowly trace the Quartus design connection and tcl script to find out what's what.
- Anyway, we don't share Max V CPLD software source code hence I don't think it's helpful for you to do the tracing either
To answer your question at high level,
- The SFP+ module should also has a PHY chip inside where user can access and configure these register.
- The SFP+ register function that you are looking at is for SFP data rate setting. SFP+ signaling rate selection, 0 <4.25 GBd, 1 > 4.25 GBd
- However, SFP+ reg access is not straight forward. I traced the design and board schematic and found out the Eth example design address 0x300000 is applied to FPGA SPI interface which is then connected to Max V CPLD on board. Finally MAX V CPLD uses I2C interface to communicate to SFP+ module.
dlim
