17 years agoinput for HDL import
Let say if i have InputAlteraBlockset with the bus type set as fractional integer [4].[4] and connect to the HDL import blockset, is that possible? What input format should the HDL import blockset ha...
17 years ago(7 downto 0) should work... if not, you can try upscaling your [4].[4] input bus to [7].[0] before passing into your imported HDL... if it still doesn't work, then chances are, you need to recheck your HDL code.
